Thanks.
The main scenario that jumps out at me is a 2 antenna application.
Antenna 1: Antennas Direct DB8e. This is a UHF only design. One panel orientated to magnetic 170. This will cover Austin's ABC, CBS, NBC, PBS and CW. Orientated other panel to magnetic heading 33. This will handle Waco's ABC affiliate and provide a shot at that Market's FOX affilaite.
Antenna 2: Antennacraft Y10713. This is a high-VHF only antenna.Orientate to magnetic heading 37. Off the front Waco's NBC and CBS should be reliable. Off the back, I would expect Austin's real channel 7 to be reliable as well as it has a pretty decent signal.
CW KCWX on real channel 5 I ignored unless you require it. CW programming is accessible via Austin.
How many TVs do you intend to serve? There are a few different ways to approach this. It all depends on length of coax, splits etc.
Cheers.
