Old 21-Dec-2010, 3:12 PM   #17
Tower Guy
Originally Posted by dprljackson View Post
I don't see why that should make a difference.
Your two strongest TV stations are too strong for the 7777, but you are not aimed at them. The results are unpredictable.
Your strongest FM stations are also too strong for the 7777, and the internal FM trap won't work low in the band on WITF-FM (89.5). To complicate the situation further, the old antenna that you have picks up FM very well.
Here's an example of overload. The 7777 is the Titan model:
http://photos.imageevent.com/holl_an...20RevK.xls.pdf
To run the calculations at your location you can actually download the Excel spreadsheet here
http://imageevent.com/holl_ands/files/ota
Don't forget to add the FM stations.
