Old 28-Sep-2014, 5:17 AM   #1
idk
wausau, wi antenna recommendation????
http://www.tvfool.com/?option=com_wr...d243f447507a08
*http://www.tvfool.com/?option=com_wr...d243b53c943775
Tvfool report links above. 1st one is at 25 ft as an estimate and second one is at 0 ft. I can not get fox in at all. I did hook up my indoor antenna rca ant 1251 outside on a cloudy but not rainy day pointing somewhat north maybe a bit n.e. and recieved nbc from rhinelander 27.1, 27.2 and eau claire 13.1,13.2, and 13.3 but still no fox 55.
I am looking to get nbc rhinelander and fox 55 wausau. All other local channels come in perfect without an antenna hooked up to tv.
I was thinking I could remove part the dish network assembly that is installed on roof and use that as my base for antenna. It is located almost to the top of roof just off to the north. No other possibilities for installing antenna outdoors is available. Attic might be option, however, if I install where dish was, I already will have coax running into the house, which gives me options to hookup to multiple tvs in house easily and coax is already grounded. Install is more for one room maybe two if it works well enough but not necessary.
Considering I was able to get these nbc channels and fox is suppose to be local to me, I imagine I do not need a large antenna, however, If I am able to get more channels from eau claire or green bay, lets just say price is not an issue.
Thanks in advance for any help in choosing the right antenna for my area and wishes.
idk is offline   Reply With Quote
