Thread: Dropping DTV
Old 21-Dec-2010, 2:04 PM   #1
okhomer
Dropping DTV
Hello all. I am needing some help. I am dropping DirecTV and have an antenna installed in the attic. The antenna I have currently is http://www.monoprice.com/products/pr...seq=1&format=2 and it is working for the most part. Channels 54, 45/46, and 13 all come in clear. Channels 11 and 2 do but channel 11 comes in clear most of the time but so often breaks up. According to the map all the channels I want are all in the same direction. Do you know why I am having a problem? Do I need a bigger antenna? Say the DB4 Antenna or ClearStream5 from Antennas Direct or something like that? Please help. Any other info I may have forgotten to mention please ask. Thanks.
I have tried Rabbit ears and work sometimes and then I have to get up and move them when I change the channel. I know...I am being lazy.
My set is...
Antenna for attic to an 8 port coaxe hub in the basement-HDHomerun in the basement to network hub to other PC. And other cables going through the house to TV in case all signals are taking up on the HDHomerun.
http://www.tvfool.com/?option=com_wr...da324aa876f7b0
okhomer is offline   Reply With Quote
