Old 25-Sep-2014, 7:22 PM   #1
ninjadogg
Help with Reception in Tualatin
n00b here looking for some help in getting my antenna setup properly.
Here is my TV fool report:
http://www.tvfool.com/?option=com_wr...d2430c1d8b9ddd
I've currently got an RCA ANT751R sitting in the attic above my garage, so maybe 12' above ground level?
From there I have a 25' run of RG6 that goes to the in-house wiring. (disconnected the incoming cable, and plugged the RG6 into that junction)
I'm on the south side of a townhouse row that is oriented North/South, with station towers almost directly to the North.
So far, I can receive KGW and KOPB just fine, and mostly decent picture on KPTV, and I want to be able to receive KOIN 6 or KATU 2, as well..
I'm checking on my HOA rules to see if/how i can put the antenna outside (there are plenty of dishes), but for now it's in the attic. The garage sticks out past the living space in those other units to my North, so and it shields it from the elements if I ever have to adjust it.... No major obstructions over the garages, (other than the beams, plywood and roofing material). The tall trees in the alley are gone, but there are those trees in the distance...... ugh, that's probably my problem, isn't it?
Would a Winegard 7964P antenna be any better for UHF reception?
I have a Samsung UN46B8000XF. I scanned both for AIR and AUTO, not CABLE. I just did a rescan, and I got these channels tuned:
KGW
8-1; 8-2; 8-3;
KOPB
10-1; 10-2; 10-3;
KPTV
12-1;
KPXG (ION)
22-1; 22-2; 22-3; 22-4; 22-5; 22-6; 22-7;
KNMT (TBN)
24-1; 24-2; 24-3; 24-4; 24-5;
KPDX
49-1;
I appreciate the help. Thanks!
ninjadogg is offline   Reply With Quote
