After reading that grounding article I feel more confused. He makes it sound like ground wire should travel the length of the coax and terminate and then down to the house ground. While shopping for cable I saw RG6 that had ground wire with it. Should I do that or can I just run ground wire from the block to the house ground like I thought?
