A J-pole mount actually is less reliable in higher wind areas than a traditional tripod or chimney mount.
I'd beg to differ since it depends more on what the J-mount is attached to.
http://www.youtube.com/watch?v=h30udVLNfSs
55 m/s = 123 mph which is a strong cat 3 hurricane wind speed. You will notice that the DB8e's J-mount is clamped to a steel I-beam so as to eliminate the variability of the mounting surface.
