After grounding the mast at the top, the coax shield at the lower end should be grounded with a grounding block to your electrical system ground for electrical safety. If you use a messenger support cable for the coax, it probably should also be grounded.
Don't try to do the whole permanent setup at once. First try a temporary setup with just one antenna and no preamp on the hill to see what you will get. It will take some trial and error to get what you want.
