Old 23-Sep-2014, 6:47 AM   #2
StephanieS
Greetings Billg,
A reception plot many would love to have!
If you just want the "big 5" - the solution is a Antennas Direct DB8e with one panel pointed to magnetic 315 and the other panel pointed to magnetic 200 will do just dandy on UHF. The DB8e is nifty because it gives a flexibility to adjust both panels to unique headings.
There are enough VHF signals in your reception area that even though likely not fully needed, I'd add a high-VHF antenna along the lines of a Antennacraft Y5713 orientated to magnetic 200.
I would expect you will have a full set of the "big 5" along with many duplicates from each market.
A Antenna's Direct EU385CF combiner would a good choice. This mounts on the mast and you hook the DB8e coax to the EU385CF UHF input and then the Y5713 coax goes to the EU385CF VHF input. Both antennas are combined to one coax heading into your home.
A preamp is likely not needed. You have a large amount of signal.
Cheers.
