Old 22-Sep-2014, 10:49 PM   #2
1. Is there a proper way to have coax cross a chasm from the top of the hill to the second story so I don't have to run additional length down the hill and up the side of the house?
Use a messenger cable support:
https://www.google.com/?gws_rd=ssl#q...+cable+support
How is the satellite guy going to run his cable?
2. Where would a drop amplifier fit into the set up due to the length of the cable run?
If you need an amp, it should be up by the antenna. We don't know yet if you will need an amp without you showing us a tvfool report for the new antenna. Use the interactive map feature for a tvfool report and place the cursor on the hill where the antenna will go. If the first signal on your report is very strong, there might be an overload problem.
3. Is it feasible to have a rotor, and run the wiring that far, or should i just have two seperate antennas pointed in their respective directions and call it good?
It is possible to have a rotor up there. You would need to use separate large diameter power wires to avoid a voltage drop to the rotor. And, your TVs would need to be able to add a channel after scan. With more than one TV, who gets to say which direction for the rotor? I favor separate antennas and A/B switches.
Your tvfool report from previous thread:
http://www.tvfool.com/?option=com_wr...d24346b4ba2335
Your previous thread:
http://forum.tvfool.com/showthread.php?t=14820
