Old 22-Sep-2014, 8:04 PM   #7
StephanieS
Hello Hank,
I didn't give a antenna recommendation because your 23' above ground plot really wasn't favorable. I wanted to see if there was any improvement with additional height.
Any antenna recommendation based on your 23' above ground plot has to be proposed with the caveat that after your installation is done, your reception may not be satisfactory. I like to have a better picture of reception situations and likely outcomes in cases like this, hence why I asked for additional TVfool plots of 50' and 100' so my antenna recommendation could be finely tuned.
Recommending antennas when the reception has a good chance of being unsatisfactory is something I am hesitant to do.
I have something in mind for your situation, but want to see confirmation (IE improvement in Huntsville signals at additional heights) that it'd be worth the work of the installation.
Cheers.
Originally Posted by twintankhank View Post
Hi, thanks for your help. Here's whats going on we are picking up some good channels from huntsville, like fox 54.1 -metv abc 31.1 whnt-dt 19.1, 19.2 and ion with a reception of about 67 max its a good picture. And were doing this with a little LAVA HD 2605 antenna and its not much of a antenna at all. Like i said before were out in open fields. Gould this be the reason were getting reception ? Anyway my no.# 1 ? is what antenna would be better for us? IF LAVA works. would a good antenna do even better ? Thank you so much for your help. hank.
