Hello Hank,
Map post successful! At your elevation of 23' above ground, your results though aren't the most encouraging. As it stands, the only stations according to this map you have a reasonable chance at are ION and the two PBSs. The remainder of signals stand a greater likelyhood of being unreliable or not viewable at all.
Can you repost additional TV fool reception plots at 50' and 100' above ground.
If you want to try for Huntsville, you may find yourself requiring a bit of investment and work. The signals at magnetic heading 309, you'll need to see them increase to 10 (nm)db or greater signal strength to really put yourself shape for reliable reception. They are approaching 80 miles so you are on the extreme fringe of them. This likely means height and a lot of it for the antenna.
Cheers.
