Old 22-Sep-2014, 10:31 AM   #2
StephanieS
Hello Dave,
Rough report I am afraid. The only good signal you have is K25NK-D which reports religious programming. KTTC NBC from Rochester on RF 10 is very weak. WKBT CBS on RF 8 from La Crosse is in the same boat and it gets worse quickly.
Your plot is currently at 30'. I would create new plots based on 50' and 100' elevations. At 30', it is doubtful you would have reception that you'd be happy with.
The goal with the new reports would be to see if the La Crosse/Rochester signals get up in the 10 - 15 (nm)db range. Then we can work with them.
You may find an investment in a tower or tree mount may be called for here.
Cheers.
