The spread between your two towers is too great for most antennas to receive both reliably.
Get a second new style C2 with the clip on VHF module (C2V), a two-port splitter, and two short (3') cables. Mount the C2 antennas at a right angle to each other with one pointed west, the other south. Combine them with the two cables and the splitter (reversed), then feed that into the VHF module which should be clipped to the reflector of the west-facing C2.
Should work.
