The co and adjacent channel warnings shouldn't matter, The potential interferers are all well off due west and should be in a -20 dB or more null of any directional UHF antenna mounted.
You can probably get by with either an 8-bay or UHF Yagi aimed at Boston. Odds are fairly good that it will also get your single VHF station on 13 or, if necessary, a small high-VHF antenna can be added for fill-in reception of that station.
If you don't have trees in front of the antenna, Boston's stations should be readily receivable.
A pre-amp may not be needed. If one is, it must be selected with care.
