Old 21-Sep-2014, 5:28 AM   #7
StephanieS
Not at all, it's what I would have suggested.
If installing in an attic going more aggressive is often just fine to compensate for the loss of signal from penetrating through your roof. Plus the DB8e gives a fine ability to adjust each panel for both the priority headings.
Originally Posted by timgr View Post
If it were me, and it would fit in the attic, I would use a UHF-only Antennas Direct DB8e and point one panel at 150ish and the other at 300ish. Probably overkill...
