Old 20-Sep-2014, 11:51 PM   #6
tomfoolery
I would ignore PBS on low band channel 5. The signal is weak plus you have another PBS that is easier to pick up.
RabbitEars also identifies WGVK real 5 as "WGVU" in the Nickname column, along with it's subchannels, so it would seem to be basically the same station as WGVU on real 11, but on low-VHF from another tower. Suggesting there's nothing to be gained with an antenna with low-VHF in this instance.
http://www.rabbitears.info/market.ph...n=wgvu#station
