Old 19-Sep-2014, 11:53 PM   #6
StephanieS
Hi Tony71Camaro,
You are right the heading of magnetic 310 gives you the best bang for the buck with Sacramento.
If I was just after Sac and nothing else, I'd be content with an Antennacraft HBU33. I'd point the the above heading.
With two TVs, you are going to have some loss from splitting the signal. How long do you see your coax run being from antenna to TV? It might be a good idea to add a RCA TVPRAMP1R preamp at your mast if your cable run is on the longer side then just split the signal two ways with a non amplified splitter.
If on the shorter side, a channel master 2 port 3412 distribution amp might be a good idea.
Cheers.
