Old 19-Sep-2014, 11:26 PM   #9
StephanieS
If mounting outdoors, you don't need a high horsepower antenna. Your signal is pretty good across the board.
A good, inexpensive and easy outdoor setup would be an Antennacraft HBU11k mounted on the included J-pole and orientated to about magnetic 250 or so.
I would expect in a clear unobstructed location (trees, buildings) that the little Antennacraft would be all you'd need.
Cheers.
