Old 19-Sep-2014, 9:14 PM   #19
sirota
Originally Posted by tomfoolery View Post
But any of them should work well for you without an amplifier.
Even if I want to split the signal to 2 TVs and using a fairly long cable run? The coax will go from the antenna mounted in the back of the house (south corner) to the front of the house where the pre-wired cable TV coax box is. The plan is to split in this box (using a grounded splitter, there seems to be a copper wire there for the ground) and then use the already pre-wired coax from the box to the rooms. Should I be concerned by long runs of coax?
Any suggestions for a 2-way splitter with ground? Any specs to look for in particular or anything you can pick up at local stores should do?
sirota is offline   Reply With Quote
