Old 19-Sep-2014, 3:43 PM   #16
sirota
Originally Posted by Stereocraig View Post
Not sure why you'd be expecting anybody to approach you w/ any negative comments.
I don't know, I'm new to the neighborhood and not sure how the neighbors would react. I was already told my front lawn was not up to standards a few days after I moved in (and it was not, they were right, but I was trying to dig out from under moving boxes, had no time to cut the grass).
Anyway, back to my original questions, still not sure what to order between ANT751, HBU11K (I probably want to get the kit here so it comes with the mounting hardware), ClearStream 2V (just because it looks a bit different and more modern though I should not be buying on looks alone, performance is more important). Any final recommendations between these 3?
And for grounding, I saw there's RG6 coax cable with an extra ground conductor on it. Would that ground conductor work to connect it to the antenna mast and then connect it to the house ground?
sirota is offline   Reply With Quote
