Thread: Noob From CT
Old 19-Sep-2014, 2:00 PM   #6
timgr
If you get the DB8e, it mounts on a single mast and has two panels. You can aim each panel independently. I would guess and aim one at about 45 magnetic and the other at about 142 (100 spread). Depending on performance, I'd then try reducing the angle between symmetrically, ie to 55 and 132 (80 spread) or something. Hopefully the channels in between would be partly covered by both panels, and the whole range would be covered.
