No, a simple splitter won't work. When you have an dedicated antenna that focuses on each band (high VHF vs. UHF) you need specialized combiner. This unit only allows UHF signals to pass on one side of the combiner, and allowing VHF signals to pass on the other then combines them both into one coax going down into your home.
The unit that has high accolades is the Antenna's Direct EU385CF combiner.
A simple splitter introduces two sets of a signal into one coax and can result in unpredictable reception.
On your mast, you'll connect the Y10713 to the VHF input and the CM4228 to the UHF input. Run coax from the combiner into your home.
Cheers.
