I see what you're saying about the signal mixing ... I wonder if it's worth trying Stephanie's
plan and skewing it slightly west to pick up WZME, but that may screw up Hartford.
Frankly, I care most about PBS, WZME, CBS and everyone else follows, in that order.
Your points are helping ... so there's no real benefit to getting that CM amp then ...
I'm going to assume that individual preamps per setup while applying a coupler after
the power source may work.
