Old 15-Sep-2014, 6:51 PM   #3
Are you correctly discerning the difference between UHF and VHF broadcasts? You only have three close-by VHF stations which operate on VHF channel 6 (WUOA), 10 (WBIQ), and 13 (WVTM).
If you have, then the most commonly encountered issue is that the TV set is still set for cable instead of being set to the "Antenna" prior to scanning.
What did you use to tie he antennas together? Uncouple the two antennas for initial setup and set them up separately. Right now, you don't have any idea of what is or isn't working right and it might be due to a mistake in the configuration.
