Hi tomfoolery
I live remote where stores are not present to buy. I need to order. So can you just explain a little more what I need?
Is an amp and Pre-amp the same thing?
I have a winegard amp now, I tried to get a model off the power plug in the basement but did not seem to be printed on it. Also the outside box is way up the tower I cannot access until I tip the tower down. I know it is a 30db gain?
Would this have the two outlets on it I need?
I am not able to climb the tower, so testing for me might be a little limited. I want to try to get it on the first shot.
When hooking up two antennas do the cables need to be the same length going to the UVSJ or the amp/pre-amp?
Thanks Dave
