Thanks for all the input. I have experimented with moving the antenna around up/down, side to side, etc as well pointing it different directions. The only real effect I can see is pointing different degree heading. Right at 300 seems to bring in everything but 40. My TV is telling me the signal strength is about -84dB whereas most everything else shows as -69 to 70dB range. I'm getting the feeling I need a bigger antenna to strengthen the signal from that station.
I also did try taking the splitter out of the equation but no big effect.
The HBU33 was recommended...why that one vs another? I know its a good antenna but is there something specific I should be looking for?
Thanks again all.
