Old 13-Sep-2014, 2:54 PM   #3
tomfoolery
Originally Posted by veekay View Post
At this point I am now getting 3 of the 4 basic channels I wanted, but it seems that the last NBC channel might be impossible to get from this location since it is on VHF.
If you're getting reliable reception on the UHF channels with a UHF antenna, then if it were me, I'd try adding a VHF antenna with the highest gain I could find and see what happens. Use it by itself, not combined with the UHF (whichever one you use in the end), for testing purposes. If you receive the channel(s) you want, combine them with either a UVSJ, or a preamp with separate inputs for UHF and VHF.
You said something about tossing it down from the attic; are you trying to install an antenna system in the attic?
tomfoolery is offline   Reply With Quote
