I now have a good idea of where to put the antenna on my shop, I'll use the eave mount as was suggested. The mast will start at 20ft. above ground and will not go much higher since in the spring we get strong winds.
I have read up on the antennas suggested and like the UHF/VHF Channel Master
CM-4228HD just for the simplicity of one antenna.
Most of the stations are UHF @ 191 deg. magnetic and are LOS. The one channel I would like to get (CBS) is @ 167 deg. magnetic and is VHF with a 2Edge condition.
Will the Channel Master CM-4228HD work since the VHF channel is 2Edge, or do I need 2 antennas a UHF @ 191deg. and a VHF @ 167 deg.?
If 2 antennas are suggested how far apart should they be on the mast?
The shop roof is metal any concerns there?
Thanks,
Charles
