Old 12-Sep-2014, 1:19 PM   #6
timgr
Originally Posted by BrianHawthorne View Post
I get tnh with rabbit ears near the TV with amazing clarity ( I forgot to say earlier), better than cable, so then I'll just need to add the UHF, and a an switch or a Y
You can buy a preamp that will combine the UHF and VHF signals. No need to A-B the antennas. http://www.amazon.com/RCA-TVPRAMP1R-.../dp/B003P92D9Y Lots of discussion of this in earlier posts if you search.
Go in the attic with your antennas and a long lead and see if the performance is sufficient.
Broadcast HD is often better quality than cable, due to less compression applied. The picture I get from WGBH here is spectacular. The women on "Mr. Selfridge" are amazing ... not that I care so much for the story, but the visuals are ... compelling.
