Looks like you and I live very close to each other because our TV Fool reports are almost identical. The only difference is that most of my stations are 1Edge probably because I live at the bottom of a hill. I am using the RCA ANR751R and it works perfectly. I also have some oak tree branches in my yard that are blocking the path of the antenna, but I haven't noticed any effect on signal quality. I'm even able to receive ION 14.1 (RF51) which is coming from directly behind the antenna. I would honestly consider trying this antenna first (which it should work well since almost all of the important channels are LOS from your location) and if for some reason that it doesn't work well, then step up to the CM 4228HD (which is a larger and more expensive antenna).
