Old 11-Sep-2014, 1:53 PM   #12
stringpower
Originally Posted by No static at all View Post
The HOA cannot prevent you from mounting an appropriate antenna on the roof. They want you to think that, but fortunately the law is on your side.
An attic antenna will likely not provide reliable DC reception with such weak signals. If frequent pixelation/signal interruptions don't bother you, then the attic might work. Found this antenna on Craigslist near you that should work well if mounted outside.
Hello No static at all, Thanks for the tip. I'm still debating wheter I will install it or not. My dad lives in Northern Virginia so I was thinking on hooking up one of those boxes that lets you watch tv using internet.
stringpower is offline   Reply With Quote
