Old 11-Sep-2014, 12:06 PM   #10
No static at all
No static at all's Avatar
Originally Posted by stringpower View Post
I can't put the antenna on my roof because of my strict HOA.
The HOA cannot prevent you from mounting an appropriate antenna on the roof. They want you to think that, but fortunately the law is on your side.
I might need to install the antenna on the attic also.
An attic antenna will likely not provide reliable DC reception with such weak signals. If frequent pixelation/signal interruptions don't bother you, then the attic might work. Found this antenna on Craigslist near you that should work well if mounted outside.
