Old 10-Sep-2014, 5:13 PM   #1
midalake
Have recommendation does seem correct?
Hi All Should say recommendation does NOT seem correct.......
I have a recommendation to run two antennas from a “local expert” I hope to explain
What I have: A 50’ tower with an unknown antenna maker. It is the “classic style with about 15 front elements a reflector and 9 wider rear elements.
I also have a winegard 30db amp.
The stations I get are: [in order of strongest to weakest] 13-6-10-3-19 STATIONS 19 & 3 are intermittent.
The antenna points to the bulk of stations 13-6-10-19 Channel 3 is a different direction
MY GOAL is to try to get ALL of the stations WITHOUT A ROTOR.
I need to get an Antenna that will receive channel 19 better with my main channels of 6-10-13-19 and an antenna to get channel 3 in the different direction.
The reccommdation is to run a HD 9032 and a y-710-13 BUT IT SEEMS that these would not get all the stations I would want
Current antenna Sorry the picture is too big do not know how to shrink
QUESTIONS:
1 Are the antennas recommended the correct ones?
2. Is there a heavy duty mount pole I may be able to get a little extra height?
3. What would be a good set-up?
My Tv report : http://www.tvfool.com/?option=com_wr...d243d2f4a77f7d
Thanks Dave
midalake is offline   Reply With Quote
