Old 10-Sep-2014, 2:05 AM   #1
shammock12@aol.com
Exclamation At my wits end..Pls help with FOX and CBS
I currently have the Mohu Leaf antenna installed and I am able to get ABC and NBC clearly; however, CBS is intermittent and FOX almost never comes in and when it does the signal is very pixelated. FOX is unwatchable. I have tried every angle in my house and tried other TVs and still no FOX. I have tried using an amplified RCA indoor antenna and still no luck. I have tried placing an FM trap on both Mohu Leaf and the amplified RCA and still no luck. I currently have the antenna pointing anywhere between 100 and 110 degrees E on an outside wall in corner wall.( have to angle it differently to get ABC and NBC). Is getting FOX impossible based on my analysis below.
http://www.tvfool.com/?option=com_wr...d2433cb028601a
shammock12@aol.com is offline   Reply With Quote
