Old 9-Sep-2014, 8:52 PM   #10
The ANT-800 preamp circuitry is built into the outdoor antenna assembly. The devise that connects power to the coax is not an amplifier, but only power supply/insertion components. If you remove the power supply of the ANT-800, the preamp circuitry inside the antenna will block nearly all signals.
If you try to power both preamps from one power supply, you risk sending the wrong voltage to one amplifier and/or overloading the one power supply that was designed power only one amplifier circuit. Even if both power supplies are of identical voltage and polarity... And have the capacity to drive two amplifiers (an assumption I would not make), you would need to have a UHF/VHF combiner that passes power on both the UHF and VHF ports. I don't believe there are any that are designed to do so.
I'm sorry, but the design of the ANT-800 removes the flexibility we desire/need in this application.
