Okay, thanks a-gain (pun intended) for all the help. I put up a 40' AGL tower with the winegard unit from my first post but was unable to put the amplifier back on it because it was already coax out and my amp is designed for 300 ohm. However, I was able to pickup 2 and 4 when they were broadcasting with no trouble. I also added a rotator and I was still able to pickup 2 and 4 over about a 30 degree range, even in the backplane when I pointed at 5. However now I can barely get a blip of 13.x, presumably because of not having an amp.
Still no sign of WLUC, wondering when they are going to up the power to 83kW? Might have better luck when the leaves come down too. I really can't get much higher without a lot more work.
Any suggestions on a good all around amplifier that will work with my coax out antenna? I'd like to boost 13, 9 if it's available, and 35 just in case. Thanks!
Right now I'm leaning toward the KT-200-COAX you suggested.
