Old 8-Sep-2014, 5:16 PM   #11
Ben Myers
KD3WB
Originally Posted by Stovepipe View Post
That's an interesting idea. I can't quite visualize how I would tilt it upward, as the antenna is mounted on a round pole with U-clamps, and the mast is mounted into the rotator. I don't think the U-clamp connector has any flexibility in the vertical plane other than perpendicular to the mast pole.
Well, even a few degrees might help. I have an antenna similar to yours and it has a little play in the vertical.
Ben Myers is offline   Reply With Quote
