The signal conditions don't appear to change significantly as you increase the mounting height. However, the terrain that blocks your line of sight toward the transmitters makes the prediction less accurate.
If you opt for a single mast mounted antenna, I would use a Winegard HD7698P or Antennacraft HBU-55. To make full use of the antenna would require that you use a rotator which can add complications... If more than one TV is connected, there will be times that the antenna is pointed the wrong way for one or more viewers. Many tuners lack the ability to manually add or 'add-scan' channels. Those TV's would require a full channel scan each time the antenna is turned.
What options do you see available to you for alternate mounting locations and added height? I'd try experimenting with these before changing antennas.
