Two antenna solution comes to mind. Two antennacraft HBU 44 antennas. One for 63 degrees and one for 230 degrees. Use a 10' mast. Fence top rail is only $12 dollars at home depot. Make sure that they are both on the same mast and at least 3' apart. If you are only using one tv, you can have an antenna go directly to the tv for one market and have the other antenna go into a sensitive converter box for the other market. It acts like an a/b switch except you are switching inputs from tv to componet or whatever you use. I would also recommend a rca tv pramp-1r preamp. You should get all green and yellow and red down to 10-15 db if outside. Good luck!
