Old 6-Sep-2014, 7:21 PM   #24
signmastr
The new reports you've posted suggest that raising the existing antenna may help your situation.
If I was in your situation, and starting with no antenna... I would use an Antennas Direct DB8E facing 147° and an Antennacraft Y5713 pointed at 180°. I'd also mount an RCA TVPRAMP1R on the mast. This preamplifier has separate inputs for a UHF antenna and a VHF antenna so the combining network would be included in the preamp, allowing for a single down-lead.
I'm already using a 10' mast with my current antenna. Will using a 15' mast with the DB8E and Y5713 and amp help enough to bother with or just stick with the 10' mast? I'm trying to avoid using guy wires.
signmastr is offline   Reply With Quote
