Thx GroundUrMast and timgr for the great explanations. Very helpful. GroundUrMast, the w27au repeater station is actually preferred, I just didn't think I would be able to pick it up since I haven't been able to yet with my old antenna. After much research this seems like a great setup, I was torn between the Winegard and Antennacraft but think I will go with your suggestion. Two more questions. 1. Will the 350° direction still pull in the 31 and 46 channels or will I need to rotate the antenna to pull them in as needed? 2. Does it matter where the preamp sits, or in other words how far from the antenna can it sit? Thanks so much for your help.
