Thread: HDTV Antenna
Old 5-Sep-2014, 7:37 PM   #4
Above the Peak of the Roof.
Install a.
CM4228HD antenna aimed at about 230 degree magnetic compass direction.
A antenna system amplifier will most likely not be required.
And Yes can also Test reception with a.
LNA-100 Boost antenna system amplifier , connected before any splitters.
http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard 3 foot or 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , Ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronhard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot and Lowes have , 10 foot 6 inch - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe.
The price is low at about 12 dollars.
