Old 5-Sep-2014, 6:58 PM   #4
Here is a way to do it to receive the long distance Tv stations that can not be received with a Tv antenna.
http://www.tablotv.com.
The Tablo receiver is installed at a location that is easier to receive the Tv stations , close to the transmitters in the USA.
The receiver is at a relatives house or friends house.
The Tablo Receiver Streams Over The Internet to your internet connection or portable internet device.
For reception of the close easy to receive , Canada / USA , Tv stations , install and Test reception with a.
http://www.channelmasterstore.com.
CM3000HD antenna installed above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the , attic , roof , building , in all directions.
As with any omnidirectional antenna , omnidirectional antennas are not 100 precent omnidirectional and will most likely need to be rotated to find the spot of best reception.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
Do not hide the CM3000HD antenna , hiding Tv antennas is a good way to have less reception.
A antenna system amplifier will most likely not be required.
Last edited by teleview; 6-Sep-2014 at 8:39 AM. Reason: Clarify information and typos.
