Thread: Antenna help
Old 5-Sep-2014, 5:04 PM   #3
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in all directions.
Install a.
http://www.antennacraft.net.
HBU33 antenna.
Aim the HBU33 antenna at about 186 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Strength Meter.
As always , the antenna location can be adjusted for best reception.
As always , the antenna aim can be adjusted for best reception.
Avoid aiming the antenna into trees and other obstructions in the directions of reception.
The Best Practice for Reliable Reception , is to install the antenna at a location that is not , obstructed , impeded , blocked , by trees and other obstructions of any type or kind including your own , attic , roof , building , in the directions of reception.
The Main groups of Tv stations are to the , South South East , South , South West , West , North West.
Here are some and not all above the roof antenna mounts.
http://www.ronard.com/909911.html. Install the , 3 foot or 5 foot , tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe. The price is low at about 12 dollars.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
Replace outside coax with NEW RG-6 Coax that has the Compression type connectors on the ends of the coax to keep weather/water out of connections and coax.
Do not use coax that has the old type crimp type connectors on the ends of the coax.
Remove and discard coax boots , coax boots take in and hold water at connections. Holding water at connections is not good.
To make double sure that weather/water does not get in to , connections , coax , and the matching transformer (balun) connected to the antenna , wrap with.
http://www.coaxseal.com.
