Old 5-Sep-2014, 10:18 AM   #5
A Simple reception situation.
The Tv stations you have listed and Many More Will Be Received.
Above the Peak of the Roof install a.
http://www.antennacraft.net.
HD850 All Channel Antenna.
Aim the antenna at about 300 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As always , the antenna aim direction and antenna location can be adjusted to for the best reception.
The Tv reception is strong signal strength at your location , a antenna system amplifier is not required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
Here are more options for antenna mounting.
Here are some and not all above the roof antenna mounts.
http://www.ronard.com/909911.html. Install the , 3 foot or 5 foot , tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.com. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
If you have any type or kind of Active Cable delivered service , be it , cable Tv service , cable internet service , cable phone service.
The cable delivered service must be on a Separate coax from the antenna system coaxes.
Yes the coaxes that are in or on the building can be used for the antenna / antenna system.
But any cable delivered service must be on a Separate coax.
If you were connected to a satellite system service.
All the devices of the satellite system must be disconnected.
Yes the satellite system coaxes can be used for the antenna system
