Can you verify what antenna you're using? Also, your original TV Fool report has expired. A link to a new report would hep us understand your situation better.
Has any moisture gotten into any cable or connectors, the symptom you describe make me think of that right away. Then, have any trees grown up into the path? Again, a common problem that will manifest as you describe.
