Old 5-Sep-2014, 12:39 AM   #8
edstevens
. . . But as you add more impediments to reception, the net result becomes less and less predictable.
In principle, I knew that but did not fully appreciate the degree to which that factored in.
TV Fool focuses on reception of the real channel, regardless of how many virtual channels are carried on the channel. Regardless of how many virtual channels are actually carried, TV Fool only lists the first one as an aid to correlating call sign, real channel number and virtual channel(s). Resources such as rabbitears.info provide more help with identifying the virtual channels.
Good info. I figured those types of questions were a bit off-topic for this forum but didn't know where else to turn. Thank you for the lead. (I am active on several forums within my profession, and on some, people seem to take the attitude of "your question indicates you need a hardware store and this isn't a hardware store. End of discussion. Now go away." instead of "your question indicates you need a hardware store - here's the address of one." )
Your opening statement, is quite true, particularly if you can not or will not consider any changes to the location or type of antenna.
Had not wanted to go to the additional complexities of an outdoor mounting, especially since all indications were that the few channels I was interested in should have been available. Will reconsider. See my previous reply in this thread.
edstevens is offline   Reply With Quote
