Old 5-Sep-2014, 12:29 AM   #7
edstevens
If you're back in "tight" to the back side of a sharply changing bit of terrain, the signal calculations become grossly overestimated, especially on UHF channels. If there are trees in the signal path, the problems gets even worse.
I put your location as a bit north and west of the intersection of Almaville and Spantown Roads, perhaps at or next to the Methodist church.
Correct. We are on Spanntown, right behind the church. Turn west out of my drive and within 0.25 mile you are headed up hill.
You're right, quite a hill behind you in the direction of the main towers which are mostly located on top the hill on I-24 heading west. Two of the three stations you're receiving (WHTN & WJFB, virtual channels 39.x and 44.x (incorrectly identified as 66.x) transmit from Lebanon and are not terrain-blocked. WSMV transmits from a tower out on I-40 two miles west of the I-440 split and it's less blocked close-in by hills. That explain the three stations you're getting.
Exactly the kind of info I was seeking. Thank you for looking into it.
Simply getting the antenna out of the attic and up in the air would very likely improve your situation. Leaving any antenna in the attic will be a failure.
I really didn't want to go to an outdoor setup, but I guess I need to look into it. My highest gable is actually pretty accessible from a lower portion of the roof, (allowing self-install) and that location would allow me to use the current pull of coax. Next question there is -- what do I need to do about lighting arrest?
edstevens is offline   Reply With Quote
