Old 4-Sep-2014, 9:01 PM   #1
Vint_age
Out in the woods in Central Mass
Hello,
First post, looking for advice on an antenna. Here is the tvfool report on my location.
http://www.tvfool.com/?option=com_wr...d243e4a2e1c15d
Looking to get the stations @113* Green and Yellow
Antenna will be mounted in the attic of a 2 story wood framed house with asphalt shingles. We are in the woods, surrounded by tall trees. At the heading that the antenna will be pointed the trees are about 50 feet away.
The antenna coax to the longest run is about 50 feet with 2 splitters.
In the days of analog tv we had an old beat up (bent and broken elements, corrosion, etc) yagi in the attic, which did an acceptable job (some ghosting) at the time for VHF, not so good for UHF. It is possible the antenna was VHF only or the UHF was not working properly. When that antenna was put into service for digital with a Motorola HDT100 tuner, the results were very spotty. Great picture one day, nothing the next. Channels had to be re-scanned often. Family got fed up and we went to cable.
I have room to put an 8 bay bowtie or a yagi up to 120" long or so.
I appreciate any advice that you can offer on antenna selection or associated equipment for receiving the local OTA stations.
Thanks
Vint_age is offline   Reply With Quote
